Blur Busters Forums
Strobing effect when watching youtube or local media files
Re: Strobing effect when watching youtube or local media fil
Postby RealNC » 27 Jun 2019, 04:19
Make sure nothing else is running, and only one tab is open in the browser. Also make sure the browser uses GPU acceleration.
Postby susalars » 27 Jun 2019, 10:33
RealNC wrote:Make sure nothing else is running, and only one tab is open in the browser. Also make sure the browser uses GPU acceleration.
Got it.
Here is the new video:
https://drive.google.com/open?id=1nlhJe ... 92aZxYu5Ys
susalars
Postby RealNC » 27 Jun 2019, 11:56
As you can see for yourself, there's no frame skipping.
Postby susalars » 27 Jun 2019, 13:22
RealNC wrote:As you can see for yourself, there's no frame skipping.
Yeah, but the issue is still there.
susalars
Postby jorimt » 27 Jun 2019, 15:06
susalars wrote:Yeah, but the issue is still there.
Because it isn't due to frame skipping, your new monitor simply has a much lower GtG than your old 60Hz monitor had.
The lower the GtG, the less blur/blending the monitor adds between frames, and at <30 FPS, this is even more pronounced, creating what you're perceiving as a "strobing effect" during pans/motion.
In other words, what you're seeing is normal for higher Hz displays with lower native GtG levels; its superior motion performance is actually exposing the inherit flaw in lower framerate content that your previous display could not.
Display: Acer Predator XB271HU OS: Windows 10 (1809) MB: ASUS ROG Maximus X Hero CPU: i7-8700k GPU: EVGA GTX 1080 Ti FTW3 RAM: 16GB G.SKILL TridentZ @3200MHz
Postby Q83Ia7ta » 27 Jun 2019, 15:49
susalars wrote:Come to think of it, are 24FPS, 30FPS videos never meant to run smoothly on say a 120Hz or 144Hz monitor?
Can't we have both smooth video and smooth 3D high FPS rendering at the same time?
Is that the origin of my "problem"?
That's the origin of your problem. 120hz monitor is capable to show 120fps (frames per second). Videos are 24fps or 30fps. On your screen, video plays/updates 24 or 30 times per seconds. With "3D high FPS rendering" screen updates 120 times per second...
Your text "It says "high CPU consumption" something like that. And I checked the taskmanager while running the test, the CPU is at about 40%." also indicates that you don't understand that's high value and it can lead to video stutters.
Q83Ia7ta
Previous
Return to Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
Who is online
Users browsing this forum: No registered users and 4 guests
