It should, yes. Longer duty cycle would mitigate the perceived flickering. Someone with a BenQ Z-series should test this.Sparky wrote:Does increasing persistence make flicker less perceptible at lower refresh rates? For example, 90hz with 1ms persistence vs 60hz with 6ms persistence? Obviously you lose some of the motion clarity, but the amount of backlight off time per frame would be about the same.
And about the topic, I have the same opinion as vega. There should be a warning when using low strobe rate AND/OR the setting should be hidden. Else there will be many complaints. People would start to associate low persistence with flickering.
