ELMB below 85hz on Asus VG248QG
Ywap
Post by Ywap » 07 Oct 2019, 04:25
Hello!
I wonder if anyone have gotten ELMB to work below 80hz on this monitor?
I´m mostly interested in 60 and 70hz.
Ywap
Re: ELMB below 85hz on Asus VG248QG
Post by Ywap » 08 Oct 2019, 04:19
….or if anyone have any 165hz Asus TN model with ELMB and have gotten the 60hz hack to work?
If so, i would be very interested to try your values in cru.
nuninho1980
Post by nuninho1980 » 05 Nov 2019, 09:49
Very probably ASUS monitor doesn't work single strobe+ELMB below 85Hz.
But do you buy a BenQ XL2411P for single strobe + "Blur Reduction" enabled the range of 50Hz and 144Hz? :)
PC specs:
CPU: i7-4790K
RAM: 2x8GB DDR3@2400MHz
MB: ASUS Z97-Pro Gamer
GPU: EVGA GTX 980 Ti SC+ :D
HDDs: SATA both 1TB+3TB
SSD: OCZ RD400 512GB
PSU: AEROCOOL 1kW 80+ Gold
Disly: LCD-LED BenQ XL2411P 24" new
Ywap
Post by Ywap » 05 Nov 2019, 10:53
Thanks alot for your reply nuninho1980!
I deeply regret not knowing this before buying this display. I´m thinking of selling this one and buy the BenQ you suggested :)
Ywap
Post by Ywap » 13 Nov 2019, 12:13
I plan on purchasing the BenQ XL2411P soon and i just want make sure of the following:
Since it can single strobe down to 50hz, it surely can do both 60hz and 70hz if i make custom resolutions?
Post by Chief Blur Buster » 14 Nov 2019, 23:23
Ywap wrote:Since it can single strobe down to 50hz, it surely can do both 60hz and 70hz if i make custom resolutions?
Yes. He said range.
The BenQ XL2411P can single strobe at any Hz between 50Hz thru 144Hz. Whether it is 60 or 70 or 93.5 or 123.456Hz.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Ywap
Post by Ywap » 28 Dec 2019, 10:42
A quick question: Is v-sync at half refreshrate (120hz strobed) comparable to real 60hz strobed?
Post by Chief Blur Buster » 28 Dec 2019, 14:26
Ywap wrote:
28 Dec 2019, 10:42
Short answer: No.
Long answer: Only when combined with software-based black frame insertion. (Like what you see at www.testufo.com/blackframes ...)
Ywap
Post by Ywap » 29 Dec 2019, 05:15
Thanks for answering Chief!
I was just wondering since 60hz v-sync:ed at 120hz (adaptable v-sync (half refreshrate) in the nvidia Control panel) sure is looking bad on my Asus display with ELMB enabled. Good to know that i can expect a better result with the Benq.
I put the purchase on hold because i ordered an LG oled tv so i can game with BFI on the couch :)
