ELMB below 85hz on Asus VG248QG
Posted: 07 Oct 2019, 04:25
by Ywap
Hello!
I wonder if anyone have gotten ELMB to work below 80hz on this monitor?
I´m mostly interested in 60 and 70hz.
Thanks
Re: ELMB below 85hz on Asus VG248QG
Posted: 08 Oct 2019, 04:19
by Ywap
….or if anyone have any 165hz Asus TN model with ELMB and have gotten the 60hz hack to work?
If so, i would be very interested to try your values in cru.
Posted: 05 Nov 2019, 09:49
by nuninho1980
Very probably ASUS monitor doesn't work single strobe+ELMB below 85Hz.
But do you buy a BenQ XL2411P for single strobe + "Blur Reduction" enabled the range of 50Hz and 144Hz?
Posted: 05 Nov 2019, 10:53
by Ywap
Thanks alot for your reply nuninho1980!
I deeply regret not knowing this before buying this display. I´m thinking of selling this one and buy the BenQ you suggested
Posted: 13 Nov 2019, 12:13
by Ywap
I plan on purchasing the BenQ XL2411P soon and i just want make sure of the following:
Since it can single strobe down to 50hz, it surely can do both 60hz and 70hz if i make custom resolutions?
Posted: 14 Nov 2019, 23:23
Ywap wrote:Since it can single strobe down to 50hz, it surely can do both 60hz and 70hz if i make custom resolutions?
Yes. He said
range.
The BenQ XL2411P can single strobe at any Hz between 50Hz thru 144Hz. Whether it is 60 or 70 or 93.5 or 123.456Hz.
Posted: 28 Dec 2019, 10:42
by Ywap
A quick question: Is v-sync at half refreshrate (120hz strobed) comparable to real 60hz strobed?
Posted: 28 Dec 2019, 14:26
Ywap wrote: ↑28 Dec 2019, 10:42
Short answer: No.
Long answer: Only when combined with software-based black frame insertion. (Like what you see at
www.testufo.com/blackframes ...)
Posted: 29 Dec 2019, 05:15
by Ywap
Thanks for answering Chief!
I was just wondering since 60hz v-sync:ed at 120hz (adaptable v-sync (half refreshrate) in the nvidia Control panel) sure is looking bad on my Asus display with ELMB enabled. Good to know that i can expect a better result with the Benq.
I put the purchase on hold because i ordered an LG oled tv so i can game with BFI on the couch
