Hello everyone new here. I'm in the process of upgrading my monitor after a beefy PC upgrade. I've always played at 60hz and abysmal fps. Now with my new rig I'm hitting 240+fps on competitive settings on all my titles so I want to upgrade to a 240hz monitor and kinda go balls to the wall...
using your amazing site and forums I've narrowed my search down to a viewsonic elite that is tuned by the motion blur man himself. I am mainly asking about 2 things...
One is if I made the right choice? I'm looking for 240 hz with good options so I can find what I prefer on these higher performances... via g sync, ulmb, or just keeping a solid 240 with nothing on. I see all these issues online with other monitors and I get the basics of it so I'm hoping for minimal ghosting and overshoot and the common complaints. This panel is rather new and highly praised so I'm quite excited.
Number 2 is settings... what are my best bets for getting a snappy smooth gameplay? I play a lot of first person shooters and I flick really hard when I have a sniper in my hands so I'm really hoping for max clarity and timing for those flick shots. If I'm getting a rock solid 240 fps should I just keep it at 240hz no strobe or sync? And lower fps I should lock it at 120 and use strobe if I'm not correct? Basically give me a full rundown here lol because I'm excited I found this my other option before was the asus xg248q.
Thanks everyone hope to hear soon.
Clarity on motion blur viewsonic elite xg270
Re: Clarity on motion blur viewsonic elite xg270
240Hz 1ms IPS panels are a really big improvement to IPS performance -- regardless of whether you like strobing or not.
The great thing is you do have a choice of both strobed and nonstrobed.
I've written pros/cons here -- 240Hz non-strobed versus 144Hz strobed along with links at the bottom of that post.
240Hz 1ms IPS panels are a really big improvement to IPS performance -- regardless of whether you like strobing or not. The better colors of IPS can also improve your ability to identify stuff quickly too. The input lag of the XG720 is incredbly low, slightly lower than some TN monitors I've used.
I've written pros/cons here -- 240Hz non-strobed versus 144Hz strobed along with links at the bottom of that post. The Right Tool For The Right Job.
You are the man. Have you got numbers yet on the input lag? I heard this thing keeps up with the input lag of the alienware aw2518hf (my first choice before I found out all about strobing and other features..) so I know the 120hz strobe is great on this thing. But how is the 240hz non strobe in comparison to TN panels? Just incase I end up wanting to switch it up?
240Hz is fantastic, well within the middle of TN territory. Unofficial numbers are posted in this thread. Incredibly low, low. It's well within TN ballpark.Themannwithaplan wrote: ↑10 Dec 2019, 07:52You are the man. Have you got numbers yet on the input lag? I heard this thing keeps up with the input lag of the alienware aw2518hf (my first choice before I found out all about strobing and other features..) so I know the 120hz strobe is great on this thing. But how is the 240hz non strobe in comparison to TN panels? Just incase I end up wanting to switch it up?
AW2518HF is a popular favourite, that said, it does not have a strobe mode if that's important to you. Having that choice is really useful especially when the monitor's strobe mode is very good.
