Hello,
I have several questions on the AOC c32g1 screen.
1. The VGA output supports 144 hz well ??
2. regarding Motion Blur Reduction : how often does it work ?
There is a way to freeze Strobe Crosstalk ?
VGA to connect old 3D glasses (96 Hz or 144 Hz), Motion Blur Reduction must improve 3D, right ?
Re: I have several questions on the AOC c32g1 screen
Normally Boost or MBR must be above 75Hz refresh rate to start.
Is there any way to use more ? 72Hz, 60Hz ?
I found this:
Vertical scan range :
50-146Hz(D-SUB)
48-146Hz(HDMI、DP)
Optimal preset resolution:
[email protected](D-SUB)
[email protected](HDMI、DP)
it looks like it supports between 50Hz and 146Hz on the VGA, but why optimal preset resolution : 60Hz in VGA ?
I found this:
50-146Hz(D-SUB)
48-146Hz(HDMI、DP)
Finally in VGA 60 Hz ... 72 Hz by overclocking.
96hz does not work (display en1440x ...).
And at 144hz : black screen.
Impossible for my 3D glasses to synchronize (60 or 72hz).
Another strange thing in DP the colors are normal (0-255) whatever the framrate.
In HDMI or DVI I have the resolutions in "ultra hd, hd, sd" are limited (16-235) ... No adjustment !
Only nv_rgbfullrangetoggle works and shows me the settings !
Another oddity when I activate the GSYNC : I have all the framrarte which are badly displayed in DP, except at 144hz and 60hz !
120, 119, 100, 96 are badly displayed !!!
And to return to normal you have to deactivate the GSYNC and rebout without plugging anything into the display port !!
I tested the MBR : less good than on my CRT ... limit to 75HZ.
not test with personal resolution.
For the gsync activate : is there a means that it works with MPC HC
