help me to choose between these 3 monitors
Posted: 27 Mar 2020, 13:46
by Tarwada
so im trying to pick the best of these 3 monitors but i'm really confused. all i want is less ghosting.
i made a comparison list in NewEgg and i need your help guys.
https://www.newegg.com/global/sa-en/Pro ... 0ZX6424311
any ideas ?
Re: help me to choose between these 3 monitors
Posted: 27 Mar 2020, 14:55
by Tarwada
also. can i run ELMB @240Hz or it will be lowered to 144Hz ?
i think Linus said something about it. maybe im wrong.
Posted: 27 Mar 2020, 20:11
by admixues
why 1st gen AUO TN panels?, also the panel in the 23.8 inch asus isn't that great.
if you want high HZ strobing just wait for the XL2546S and even that would look much better with the 180/181hz trick.
Strobing at a lower HZ than the monitors maximum = lower cross-talk.
if you want a monitor now i'd get the XF252Q or KD25F, the XL2546S probably got delayed thanks to covid-19, AUO and BenQ are both located in taiwan but the rest of the supply chain isn't necessarily there, there is also that 360HZ panel coming which will hopefully do ULMB at 180HZ as it has a g-sync module.
if you must get a monitor now and you want good strobing get the XL2546 from jarir it's on sale,
Posted: 28 Mar 2020, 07:59
by Tarwada
i really don't know how did u know about jarir. dude, the alienware 25 monitor is 1200SR in new egg and 2300 in jarir shop lol
for me, i want low input lag and minimum ghosting. i will never use g sync cuz all i play is competitive games.
i also only want 25" monitors. 27" is too big for me.
