Inconsistent in-game frame rate limiters and vsync.
Posted: 15 Apr 2020, 13:49
by insight2
Lately I played the new FPS game Valorant. The in-game FPS limiter seemed good, it gave me a steady 235 fps value. I turned on my monitor built-in fps counter to check, and I realized the framerate was fluctuating a lot, often reaching 239 fps (vsync cap) even tho I had a 235 fps cap in game with v-sync on. Testing with riva tuner confirmed this, by lowering the fps refresh delay from 500 to 50 on RTSS, I noticed the framerate and frametimes were, in fact, really inconsistent. So I decided to disable V-sync and test again. This time without the vsync cap, I noticed the framerate was exceeding often my fps cap for some fraction of seconds. This bevhavior might trigger the vsync input lag, I suppose (correct me if i'm wrong).
Now I can't choose. My choice is to either cap my fps in game to something like to 225 hoping the framerate won't exceed my monitor's refresh rate, or disable vsync. But with vsync disabled the image isn't smooth at all cause the frametimes are inconsistent.
Using an external frame cap like riva tuner fixes everything, but I am not sure the additional input lag is worth it, considering FPS games need super low delays.
I am not sure what to do. I am a competitive player, but I also want a good image quality, tearing is DISTRACTING. I hate it.
I hope i explained myself properly, if not I apologize.
Hopefully you guys will test the game and find the perfect settings, i'm sure many people would be interested as well.
Thank you!
Re: Inconsistent in-game frame rate limiters and vsync.
Posted: 15 Apr 2020, 14:50
by knypol
Noticed this as well in many games when limiting fps to 234-237 . Not sure what is more accurate monitor fps counter (gsync monitor) or the in-game counter. Only when i limit to 229 (or less) monitor counter doesn't exceed 237.
Posted: 21 Apr 2020, 06:02
by Avean
No way! I trusted the in-game fps limiter as well. Also playing Valorant. Checking now, in-game fps limit to 167. Monitor showing me hitting 170 several times enabling vsync. So i tried setting 160 fps limit in-game and im STILL hitting my max refreshrate 170 several times. Tried setting fps limiter through NVCPL and also there its hitting 170. I assume the monitor is telling me the correct framerate.
I had no idea this was an issue, thanks for posting this! Knowing this now i feel disabling v-sync is the way to go even with more unstable frametimes but its only jumping between 2-3 ms in my case if i let my fps fly up to 350. Also i get lower input lag. 2.2ms instead of 5.8ms.
But i wonder how many of us is having this issue cause g-sync but v-sync is pretty much a norm these days. They would have no idea they are hitting v-sync territory without checking theyre monitor.
Posted: 21 Apr 2020, 10:24
by insight2
Yeah, that's exactly what I wonder as well. If all these spikes trigger vsync, it's a huge problem. (maybe that's why nvidia ultra low latency caps fps at 225? to avoid this issue).
For now I locked my fps to 225 from the in-game option and they are steadily under 239, still I am considering disabling vsync for the moment. The problem is that the built-in in game fps cap is not so stable and it the game doesn't look really smooth with uncapped fps. Lower input lag is nice, but it's not worth the tradeoff in my opinion.
Maybe someone who knows more than us will be able to tell us more.
Posted: 21 Apr 2020, 10:37
by jorimt
I've discussed this multiple times on the forums before, but to sum-up, take the monitor's built-in refresh rate meter during G-SYNC operation with a grain of salt (especially those on FreeSync monitors running in G-SYNC Compatible mode), as it doesn't use the same averaging as system-side FPS readouts, and is prone to what you describe.
For what it's worth, during my original input lag test for the G-SYNC 101 article, I saw similar spikes on my monitor's refresh rate meter, and it did not end up directly affecting average input lag; as long as you use G-SYNC + V-SYNC + a minimum -3 FPS limit, the V-SYNC option should compensate for any of the frametime variances that occur (including the "spikes" you are seeing on the refresh rate meter).
My advice is to rely on the system-side FPS readouts for average FPS instead, and to only rely on the refresh rate meter to determine whether G-SYNC is engaged in the given game (fluctuating = VRR mode, constant static number = Fixed refresh mode).
Posted: 21 Apr 2020, 11:07
by insight2
jorimt wrote: ↑21 Apr 2020, 10:37
Thank you. That's all i wanted to know. I use a PG258Q G-Sync monitor, i'll lock the FPS to 235 then, just to be sure.
