Using a VG278H on Windows 10 fully patched.
I think my issue might be that the Device Manager is listing my Monitor as a Generic PnP Monitor.
I have tried to locate drivers for my display but coming up empty. So my guess is that strobelight.exe is referencing the Device Manager and since the supported monitor isn't on the list, it doesn't work.
I recall years back that strobelight.exe would go into the start up folder. After installation I don't see it anywhere in the startup sequence. I guess I have to add it manually?
Also when I log into windows I get a "incorrect cable. please use the dual-link dvi cable that came with your monitor." error. I guess I need to try another cable? The display runs at 120hz fine with this cable but no lightboost.
A link to the cable I'm using.
CableCreation Active DisplayPort to DVI Cable, 6ft DP to DVI-I Cord, Eyefinity Support Multi-Screen, 1.8M Black
https://www.amazon.com/gp/product/B019Q7I2M0
VG278H no longer working with lightboost
Return to “Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
