Hello I am new to this forum im kinda lost with overdrive
g280
Post by g280 » 12 Jul 2020, 22:35
Hello I am new here I and I am kinda lost cause I just got a Asus VG259QM and I was researching and i read that 80overdrive works better on the 27' version of my monitor and 60 for my version. Can someone clarify this tome cause I am kinda lost. Thanks
axaro1
Re: Hello I am new to this forum im kinda lost with overdrive
Post by axaro1 » 14 Jul 2020, 08:33
The overdrives on the VG259QM are shifted compared to the VG279QM.
OD60 on the VG259QM performs like OD80 on the VG279QM.
OD80 on the VG259QM is something inbetween OD80 and OD100 on the VG279QM.
OD100 is unusable in both the VG259QM and the VG279QM.
OD80 is really good at 280hz, there's barey any overshoot and motion clarity is very good, OD60 is more suited to 240hz.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
g280
Post by g280 » 18 Jul 2020, 08:08
Thank you I use most 240hz but I'm staying on 80 overdrive cause I don't see much difference. what I noticed is that this monitor have ghosting. I had a VG248QE and it has ghosting too and on the VG259QM it seems to have ghosting too. So I was wondering if I should RMA it cause it's working fine just a bit of ghosting when playing valorant and I don't see ghosting when Im whatching something on YouTube. The monitor is fine for me I would not return just because I don't have much knowledge so I want to hear from another person perspective because it's a very expensive panel and I want to make sure it's working properly. Thanks for the attention
g280
Post by g280 » 18 Jul 2020, 15:16
I did not notice any ghosting on test UFO only when I move mouse fast while gaming or in my cursor on the desktop
g280
Post by g280 » 19 Jul 2020, 06:56
Im using 60 od now feels much better thank you
