Gwyndael wrote: ↑07 Nov 2020, 20:47
Out of interest, why would I want to turn off PureXP if that's what is contributing to reducing motion blur?
There is motion blur only because refresh rates are too low to eliminate motion blur strobelessly.
500fps 500Hz nonstrobed has identical display motion blur to LightBoost 100% (1/500sec = 2ms MPRT)
1000fps 1000Hz nonstrobed has identical display motion blur to LightBoost 10% (1/1000sec = 1ms MPRT)
Nonstrobed means LightBoost OFF, PureXP OFF, ULMB OFF. Flickerfree blur reduction. Except it looks vastly better for other reasons (full brightness, full color, fewer stroboscopics). We are dependant on strobing to eliminate motion blur only because refresh rates are not high enough to eliminate motion blur strobelessly. Strobing is a humankind band-aid. Blur Busters loved strobing for many years, but strobeless blur reduction is the motion blur Holy Grail of 2030.
Right now, the state of art in strobeless blur reduction is the VG259QM (280Hz) and PG259QN (360Hz) which strobelessly can already achieve better than half the motion blur of 144Hz LightBoost=OFF ... (Though both have strobe features too). The XG270 is really good though, with excellently tuned 100Hz-to-120Hz motion blur reduction, in a massive improvement to your VG248QE, and even the mere 240fps at 240Hz PureXP=OFF will have less motion blur than 144fps at 144Hz LightBoost=OFF, so you still have both options.
Chief Blur Buster wrote: ↑06 Nov 2020, 22:49
If you upgrade infrequently, then after 240Hz, you should consider switching from strobing-based approach to strobeless motion blur reduction.
I take it that "strobeless motion blur reduction" is essentially whatever the monitor is able to provide with its motion blur tech turned off e.g PureXP; ULMB etc?
Correct. Entry-level strobeless motion blur reduction has already essentially arrived with the 360Hz monitors in a sense, and monitors are expected to reach 1000Hz by the end of this decade. ASUS Has confirmed their "Road to 1000Hz" to Blur Busters and PC Magazine, at CES 2020 a year ago.
If you buy something now, then if you upgrade only once every 5 or 10 years, your 2nd upgrade in year 2025 or 2030 could conceivably switch to strobeless motion blur reduction which is more eye-friendly (no flicker, no stroboscopics). Just informing you of long-term planning of the preferred method of motion blur reduction via brute framerate & refreshrate.
For more information of the newer long-term Blur Busters preference for strobeless motion blur reduction:
- Pixel Response FAQ: GtG Versus MPRT
- The Stroboscopic Effect of Finite Frame Rate
- Blur Busters Law: The Amazing Journey To Future 1000 Hz Displays
- Frame Rate Amplification Tech: Cheaper 1000fps GPUs Of The Future
So what I'm getting from this is that unless you have the hardware to directly match the fps to the max hz of the monitor (which isn't likely to happen until ETA 2022), utilising whatever motion blur tech the monitor has and matching the fps to it is going to provide the best motion clarity results? This is because the motion blur tech helps control the MPRT, and monitors with good out of the box MPRT are still not widely available?
MPRT is equal to (1/frametime) on a non-strobed display assuming GtG is a tiny fraction of a refresh cycle. The math becomes simple. If you want 2ms MPRT without strobing, it requires 500fps at 500Hz on a sample-and-hold LCD or OLED (non-strobed, LightBoost=OFF, PureXP=OFF, ULMB=OFF), which is explained in the Pixel Response FAQ link (GtG-vs-MPRT).
Don't worry about it this upgrade cycle, unless you're attracted to trying 360fps at 360Hz to get the world's lowest motion blur stroblessly. For now, just get strobed 120Hz and keep frame rates low enough (framerate=Hz). It is a bit too earlybird to go the strobeless route unless you've already purchased an RTX 3080+ to push the 360fps in enough games.
That said, VG248QE came out more than 5 years ago, which means if you upgrade now (2020) you'll still prefer strobing, but next upgrade cycle (in 6-to-10 years) will be in the strobeless blur reduction era. I'm just giving you friendly advance warning of upcoming technology changes
You may still want to keep using strobing even in that era, since not all games run at sufficiently high framerates to become motion-blur-reduced strobelessly.
For example, why I'm currently using Strobelight at 120hz strobed on my VG248QE and setting games to 120 fps to match it; rather than running the monitor out of the box at 144hz.
Two different things. Apples versus oranges. My answer is below.
For example, why I'm currently using Strobelight at 120hz strobed on my And while a monitor is capable of 240hz, having it strobe at a lower hz helps the strobe quality? e.g why the strobe quality on my 144hz VG248QE sucks lol
I already answered this in this article,
CRT Nirvana Guide for DIsappointed CRT-to-LCD Upgraders. The short story is you need enough pause between refresh cycles
in order to hide GtG between refresh cycles. If you strobe too close to max Hz, you have more double images (strobe crosstalk), as explained in the
Strobe Crosstalk FAQ. You really want framerate=Hz
AND a Hz below max Hz, to have high quality strobing on an LCD. This is because the VBI (vertical blanking interval) between refresh cycles needs to be a long-enough pause between refresh cycles to allow LCD GtG pixel response to finish in total darkness before the strobe backlight flash. It's also seen in
High Speed Video of LightBoost.
So the XG270 with PureXP on and set to 120hz and matching refresh rates is still my best choice for motion clarity and colour; and there's no new batch of 240hz monitors on the near horizon that will make the XG270 a poor choice for the next 5 or so years?
Impossible.
Technology in this arena has improved so fast. VG248QE's LightBoost became obsolete 4 years ago with vastly-better quality and lower-lag strobing options years ago. You will likely be happy with XG270 though. Just there is always something better in less than 5 years, from ViewSonic and from others. This is my straight face. Gaming monitor technology is improving faster than it used to be.
Choose your favourite moving target and hit it.
