Not sure if this a thread necro, but I got the XG270 from viewsonic, the blur reduction is amazing at high refresh rates, chief did not give out the 'Blur Busters Approved' logo lightly. Its very disappointing it does not have the 60hz single strobe option, also having it be 1440p or 4k would have been great too, 1080p on 27inch in this day and age is a big ask for regular blur free non-Esport gaming. Growing up gaming on a CRT has been a curse it seems.
Chief mentioned they are working with a big monitor manufacturer for 60hz strobing, any news on that?
Good News Everyone: 60Hz Single Strobe Options
Re: Good News Everyone: 60Hz Single Strobe Options
With Elden Ring out and capped at 60fps, how is everyone playing this game?
Personally I am playing it a LG TV which has a single strobe option at 60hz, otherwise I am playing it with vrr on my monitor. But prefer the 60hz strobing option as its overall much more clearer in motion. We really do need some more good 60hz single strobing options for monitors beyond 1080p, and its unlikely the new alienware QD-OLED screen will have that option.
Any news on upcoming 60hz single strobing options?
Here's something to note with single strobe 60Hz and wide gamut KSF panels specifically. Red ghosting becomes too aggressive at such low refresh rates. So beware. KSF-free panel is required to not have these issues.
This is M32Q single strobing at 60Hz (inside bugged vrr strobing mode) Overdrive OFF, aim stabilizer at middle screen, 960pps
Does the M32Q need some additional software or firmware update to do 60hz single strobe? I'm thinking on this one for a new arcade machine project with Retroarch. I thought that monitor did only strobe at higher refresh rates. How's the crosstalk? Crosstalk on the XG2431 looks sweet, but it's sadly too small to my liking. If I'm not mistaken the Eve Spectrum also has a red ghosting.
I can't recommend using this bugged mode. It's too dark (~100 nits), it flickers if frame rate varies, it naturally flickers due to low 60Hz refresh rate, and the ksf decay is distracting. Scaler doesn't allow large VT mod like XG2431 so crosstalk isn't great either. I also can't guarantee this bug will work for everyone.DeFierro wrote: ↑16 May 2022, 23:10Does the M32Q need some additional software or firmware update to do 60hz single strobe? I'm thinking on this one for a new arcade machine project with Retroarch. I thought that monitor did only strobe at higher refresh rates. How's the crosstalk? Crosstalk on the XG2431 looks sweet, but it's sadly too small to my liking. If I'm not mistaken the Eve Spectrum also has a red ghosting.
M32Q 60Hz single strobe crosstalk
Have you tried a ToastyX DisplayID extension block to try to swap Front Porch and Back Porch (use ultralarge Front Porch versus ultralarge Back Porch), to see if it artificially shifts the crosstalk?Discorz wrote: ↑17 May 2022, 01:19I can't recommend using this bugged mode. It's too dark (~100 nits), it flickers if frame rate varies, it naturally flickers due to low 60Hz refresh rate, and the ksf decay is distracting. Scaler doesn't allow large VT mod like XG2431 so crosstalk isn't great either. I also can't guarantee this bug will work for everyone.
Some displays keys the strobe flash based on the location of the VBI boundaries (e.g. the boundary between Sync and Front Porch, or the boundary between Sync and Back Porch). Those models can have strobe crosstalk tricked to shift simply by moving the ultralarge value to a different section of the VBI (porch or sync).
This will not work if the strobe flash is keyed to the beginning or end of the visible resolution, it only works on models whose strobe flash is keyed on one of the boundaries between two different VBI areas.
No matter what combination I do it doesn't shift crosstalk. Changes do get applied as amd panel reports. I assume its keyed to beginning or end of resolution.Chief Blur Buster wrote: ↑17 May 2022, 17:36Have you tried a ToastyX DisplayID extension block to try to swap Front Porch and Back Porch (use ultralarge Front Porch versus ultralarge Back Porch), to see if it artificially shifts the crosstalk?
Ah, yeah, no strobe-phase hacks seem available externally.
Thanks for trying, though!
tl;dr:
Oculus Quest 2's chineese knock off Pico Neo 3 enters Europe and probably other markets soon.
Since it's in general a better option for PC VR users, I am wondering if it could be a good single strobe option too, just like Quest 2 is.
Does it even support 60Hz? Does it allow to change the refreshrate freely? Is it working well? Is the moving objects clarity as good as Quest 2?
Some info what it is:
First of all, It's 450€, but has DisplayPort connection, equivalent of elite strap (so it isn't uncomfordable as standard Quest 2) and has the link cable included in the box. Sure, it's Chineese with all the cons it brings in, but it doesn't require you to login to Facebook (surely Chineese driver software has the spying side of it covered already )
The chip inside is the same XR2 as in Quest 2. Slightly higher clocked, likely to compensate for the advantages Quest 2 has from its polished software stack. The initial reviews suggest it's a surprisingly good option. The headset was previously sold only in China, where it gained substantial popularity.
