asus vg245 service menu OD gain?
does anyone know how OD gain works on asus monitors? do i set Tracefree to 100 then turn OD gain down until i dont see ghosting?
Re: asus vg245 service menu OD gain?
OD Gain is like a continuum from ghosting all the way to coronas. You can view www.testufo.com/ghosting or one of www.testufo.com/photo while adjusting this.
P.S. Although it's kind of an unwritten rule at this stage, please allow at least a few days -- 72+ hours -- before bumping up posts (removed bump post).
To support Blur Busters:
• List of G-SYNC Monitors
• List of FreeSync Monitors
• List of Ultrawide Monitors
will still get ghosting if set tracefree to 100 and torn od gain down though?
OD Gain and Tracefree is the same thing.
OD Gain is simply giving you finer adjustments.
OD Gain = like Tracefree in "+1 increments" instead of "+20 increments"
OD Gain 1 = Tracefree 1
OD Gain 2 = Tracefree 2
OD Gain 3 = Tracefree 3
OD Gain 4 = Tracefree 4
OD Gain 5 = Tracefree 5
OD Gain 6 = Tracefree 6
[etc]
[etc]
[etc]
OD Gain 95 = Tracefree 95
OD Gain 96 = Tracefree 96
OD Gain 97 = Tracefree 97
OD Gain 98 = Tracefree 98
OD Gain 99 = Tracefree 99
OD Gain 100 = Tracefree 100
Something like that, although it does not always symmetrically map 1:1 on all models. But you get the idea.
ok thanks i got it
Sometimes you may have a situation (on some models of monitors) where the gain stack on each other. For example Tracefree might be one setting added to OD Gain in a different setting (e.g. Retail Overdrive 20 and Factory OD Gain 30, might translate to the equivalent of OD Gain 50 (20+30)) on a different brand than ASUS.
However, I think in your specific case, OD Gain overrides the Tracefree setting.
ok understandable in that casei think imma leave tracefree at default 60 and set od gain where i dont see ghosting instead of tracefree 100
