asus vg245 service menu OD gain?
Posted: 20 Dec 2020, 21:50
by solidcam
does anyone know how OD gain works on asus monitors? do i set Tracefree to 100 then turn OD gain down until i dont see ghosting?
Re: asus vg245 service menu OD gain?
Posted: 21 Dec 2020, 14:41
OD Gain is like a continuum from ghosting all the way to coronas. You can view www.testufo.com/ghosting or one of www.testufo.com/photo while adjusting this.
P.S. Although it's kind of an unwritten rule at this stage, please allow at least a few days -- 72+ hours -- before bumping up posts (removed bump post).
Posted: 21 Dec 2020, 17:31
by solidcam
will still get ghosting if set tracefree to 100 and torn od gain down though?
Posted: 21 Dec 2020, 17:34
solidcam wrote:
21 Dec 2020, 17:31
OD Gain and Tracefree is the same thing.
OD Gain is simply giving you finer adjustments.
OD Gain = like Tracefree in "+1 increments" instead of "+20 increments"
OD Gain 1 = Tracefree 1
OD Gain 2 = Tracefree 2
OD Gain 3 = Tracefree 3
OD Gain 4 = Tracefree 4
OD Gain 5 = Tracefree 5
OD Gain 6 = Tracefree 6
[etc]
[etc]
[etc]
OD Gain 95 = Tracefree 95
OD Gain 96 = Tracefree 96
OD Gain 97 = Tracefree 97
OD Gain 98 = Tracefree 98
OD Gain 99 = Tracefree 99
OD Gain 100 = Tracefree 100
Something like that, although it does not always symmetrically map 1:1 on all models. But you get the idea.
Posted: 21 Dec 2020, 17:39
by solidcam
ok thanks i got it
Posted: 21 Dec 2020, 17:41
solidcam wrote:
21 Dec 2020, 17:39
ok thanks i got it
Sometimes you may have a situation (on some models of monitors) where the gain stack on each other. For example Tracefree might be one setting added to OD Gain in a different setting (e.g. Retail Overdrive 20 and Factory OD Gain 30, might translate to the equivalent of OD Gain 50 (20+30)) on a different brand than ASUS.
However, I think in your specific case, OD Gain overrides the Tracefree setting.
Posted: 21 Dec 2020, 22:21
by solidcam
ok understandable in that casei think imma leave tracefree at default 60 and set od gain where i dont see ghosting instead of tracefree 100
