Hello guys!
I recently bought myself a new monitor, the Asus TUF VG27AQ1A . I'm using all the default cables (Display Port and Power Source). The was I set it up is: I turned OFF adaptive sync (g-sync) inside the OSD and Nvidia Panel. I turned on ELMB and did some slight adjustements to the Temp setting. Overclocking ON and set at 170Hz.
My problem is:
When moving my cursor on the desktop, especially on dark backgrounds (Spotify for example) or while playing Warzone (~70-80fps), I notice what you guys I believe refer to red phosphorus. I basically see ghosting and can make out the RBG in some cases, red being the most prominent. Is it that my monitor is broken or have I set it up wrong? Can I do something to get rid of the RGB ghosting or do I just have to live with it?
Any suggestions are welcome. If you can recommend a better 1440p 165Hz IPS monitor with Low Motion Blur in the same price range, please do!
TUF VG27AQ1A red phosporus / rgb ghosting?
Return to “Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
