Hello all,
I am looking for smartphones and tablets using black frame insertion - strobing - from 60hz to 120hz with variable refresh rate.
I do not look at high refresh rate specifically, but strobing is mandatory to me.
I saw on Blur Buster that the Sharp Aquos Zero 2 uses this strobe.
Has anybody already tested it ? Is there a possibility to tune the refresh rate from 60hz to 120hz (via an app for example) in order to replicate monitor's lightboost ?
Thank you everybody !
Sharp Aquos Zero 2 _ strobing _ variable refresh rate ?
Re: Sharp Aquos Zero 2 _ strobing _ variable refresh rate ?
No I haven't but I recommend the sony xperia 5 III (coming later this year) has backlight strobing as well as the sony xperia 5 II or sony xperia 1 III (too expensive imo)
Thank you very much ! I ll have a look
