Hello,
I'm looking for a way to eliminate motion blur from my monitor. I've noticed whenever I'm playing VALORANT, enemies are zooming past my screens. I currently have an Alienware aw2521h 360hz monitor paired with an AMD Radeon 6800XT but i've come to the sad realisation that ULMB is not supported by AMD.
Is there any chance I can reduce/eliminate input lag or did I screw up with what I purchased?
Thanks.
Eliminating Motion Blur on my monitor
Re: Eliminating Motion Blur on my monitor
Are you sure ULMB doesn't work with amd? Have you checked on that? Or is it greyed/locked out in monitor osd?
AW2521H user manual says:
"NVIDIA ULMB (Ultra Low Motion Blur) helps have less of a motion blur effect while you are watching fastmoving images. When the graphics card supports GSYNC, make sure that the Enable G-SYNC function is not selected in the NVIDIA Control Panel.
NOTE: This function is available when the refresh rate is 144 Hz or 240 Hz with DP connection. Ensure that the DP cable is directly connected to the monitor DP port. This function is not available when connecting DP through a dongle/hub.
NOTE: When G-SYNC is enabled in the NVIDIA Control Panel, the message of G-SYNC Mode is displayed. If your system doesn’t support G-SYNC, then the message of Normal Mode is displayed."
So make sure u disable G-SYNC if possible, use proper refresh rate and cable.
Thank you so much for the reply. ULMB is a Nvidia ONLY thing. G-Sync is only supported by Nvidia. AMD uses FreeSync instead. And yes it is greyed out on the monitor osd when I set my monitor to 240hz.
Would there be other software's that could mitigate this problem?
Adaptive-sync/G-SYNC (not processor) needs to be disabled for ULMB to work. Is it possible to disable only that on this monitor? Can you send some pictures of your osd?
I know ULMB is nvidia tuned strobing but that shouldn't mean it won't work on amd. Unless they purposly made it like that.
Hey Thanks for the reply.
So I've turned my monitor down to 240hz and have made sure adaptive sync and freesync is disabled and the ULMB setting is still greyed out on my monitor. :/
Guess i'm stuck like this right?
Idk man. Maybe someone else can help you further. Bur it does sound like it shoulf work.
Try turning HDR off.
This is why Blur Busters Approved moniors does not have a Hz restriction on strobe backlights. We hate presets (Such as "85, 100, 120" or "120, 144, 240") and we believe all refresh rates should be strobeable.
Any updates on this nehry? Or others that have the aw2521h?
I noticed a post on a dell support page for a 2518 where the dell support guy said gsync can be off if you are in 60hz mode but if you want to go higher hz then gsync needs to be on. "To get any Hz above 60, G-Sync must be on". The guy with the monitor kept on trying to turn off gsync but it automatically turned back on.
I am just curious if it has an issue where you try to turn off g sync then the module keeps turning it back on?
Generally, on the majority of monitors, it is possible to turn off VRR (G-SYNC or FreeSync) without any refresh rate sacrifice.
If this is an actual DELL Alienware support page with accurate information, I’d like to see a link to it — just in case it was misunderstood or required some simple additional steps (e.g. another setting) to keep high Hz with and/or without VRR.
If this is a bug caused by missing EDIDs (plug n play signalling) in non-VRR mode, try manually creating high Hz modes in a Custom Resolution Utility (NVIDIA or ToastyX).
Make sure to use DisplayPort, rather than HDMI for this particular situation. HDMI may work fine at high-Hz but on older native G-SYNC chipped monitors, your refresh rate options may be maximized by trying DisplayPort.
