240HZ Monitor but only 180FPS in game
andro
Post by andro » 18 Aug 2021, 11:00
Would u recommend using "highest available" in nvidia settings at this point?
i dont know if i have more input lag when i set to 144 and use prefered refreshrate.
Re: 240HZ Monitor but only 180FPS in game
Post by RealNC » 18 Aug 2021, 12:11
For latency, "highest" is always best as far as I know. From a smoothness perspective, "highest" is also best when using VRR (freesync/g-sync). Without VRR, matching FPS and Hz is best for smoothness.
andro
Post by andro » 19 Aug 2021, 17:54
RealNC wrote:
18 Aug 2021, 12:11
When i use Highest i Play on 240hz With only roundabout 190-200 fps. Wouldnt that be stuterring af? I currently use 200 fps and Turn down refresh Rate to 144 hz
Post by RealNC » 20 Aug 2021, 06:35
andro wrote:
19 Aug 2021, 17:54
With VRR active, it doesn't stutter. Without VRR, yes, it will stutter. But in this case it's called "judder", to differentiate between the stutter of FPS/Hz mismatch and the stutter created by the game itself.
