I currently using a ASUS PG279QZ and want to use it as my secondary monitor on my desk once I found a suitable replacement. I had settled on the Asus PG279QM but saw the price of $899! That price is hard to swallow even though video reviewers say they saw noticeable improvement between the two.
Is there anything almost identical to the Asus PG279QM at a more reasonable price? I'd go to a bigger monitor but not confident there is anything that has less motion blur/ghosting than my current ASUS PG279QZ.
Anything with similar function/specs to the Asus PG279QM
Re: Anything with similar function/specs to the Asus PG279QM
Few monitors mentioned here: viewtopic.php?f=2&t=8988
