Hi
I changed my monitor to ViewSonic XG270. Earlier I was using Benq XL2546. But I have trouble playing for more than an hour. I like viewsonic. When I tried to enable Adaptive Sync and PureXP I am not able to use PureXP if Adaptive Sync ON. And I tried to check monitor firmware update but Elite Display controller is crashing.
I appreciate your comment and suggestion on this.
Edit: I fixed Elite Display Controller Crash.
Thanks
Badri M
ViewSonic XG270 and XBOX Series X
Re: ViewSonic XG270 and XBOX Series X
Hello,badrisuper wrote: ↑02 Oct 2021, 09:32Hi
Currently, PureXP cannot be used simultaneously with VRR technologies such as FreeSync (VESA Adaptive Sync). Most strobe backlights (LightBoost, ULMB, DyAc, etc) can't be used simultaneously with VRR. Even the BenQ monitor models that supports FreeSync VRR can't do DyAc at the same time.
It is not a ViewSonic-specific limitation. You will have to choose PureXP or FreeSync.
Some monitors do support variable strobing now, e.g. ASUS ELMB-Sync, as well as Gigabyte Aim Stabilizer Sync, as well as some VRR strobing I'm currently working on for a future monitor (12-24 months).
Thanks Chief. I disabled Adaptive Sync and started using PureXP. I can see lot of difference in games when I compare it to my Benq Monitors.
For XBOX Series X, what could be the good setup? I dont think I have much choice when it comes to gaming console.
At present I am using below config.
Custom 1: PureXP (Normal or Ultra depends on what time I use), Gamma 2.2, Black Stabilization 12. Any other setting I have to consider or change?
Thanks
Badri M
Thanks
Badri M
Hi
I observed that if I enable PureXP Response Time OD is disabled. I cannot use both?
Thanks
Badri M
Thanks
Badri M
badrisuper,
How did you fix the Elite Display Controller crashing? I've had it work and not work multiple times since I've owned the XG270 but I can't seem to get it to work this time.
