G-Sync with dual monitor (G-Sync compatible & non-Gsync)
Re: G-Sync with dual monitor (G-Sync compatible & non-Gsync)
Post by RealNC » 17 Jan 2025, 11:38
WillZM wrote:
17 Jan 2025, 11:01
I can't, my main monitor is using DP, the secondary is using HDMI (no DP port). I don't think it's the port though, I have tried my old monitor but with true GSync support, (Acer XB271HU i think). That monitor is using DP as well, and when paired with the secondary non-Gsync monitor, I checked that the MPO is enabled for the XB271HU and disabled for the secondary.
Perhaps the MSI monitor itself is not supported? It is FreeSync Premium, not GSync. Is it possible that this is the root cause?
I don't know. You might wanna ask on the SpecialK discord.
