Anyone else w gsync playing this Beta? The game's fps is supposedly locked to your displays refresh rate, and it seems when you have gsync enabled the game selects 60hz as the "default" if you could call it that. So basically when I play Titanfall with Gsync enabled I'm stuck at 60fps. Bummer.
Also.... Are developers seriously gonna keep doing this to PC gamers?
Titanfall [frame capped to 60fps]
Re: Titanfall
This is a beta -- and betas invite feedback -- why don't you report the bug to the developers?hashtonkutcher wrote:Anyone else w gsync playing this Beta? The game's fps is supposedly locked to your displays refresh rate, and it seems when you have gsync enabled the game selects 60hz as the "default" if you could call it that. So basically when I play Titanfall with Gsync enabled I'm stuck at 60fps. Bummer.
Ideally, it should attempt to sync to the maximum refresh rate that G-SYNC is set at (e.g. 144fps), and let G-SYNC handle smoothing-out any frame rate slowdowns.
(ManuelG at NVIDIA, you might want to give them a call, too.)
hashtonkutcher
Re: Titanfall
Point taken, reporting it now. I can't be the only one getting tired of all these games with locked framerates and what have you though.
Re: Titanfall
I've added it to Hall Of Shame for now:
http://forums.blurbusters.com/viewtopic ... 2974#p2974
Haste
Re: Titanfall
Excellent initiative! I'll help with populating it.Chief Blur Buster wrote:I've added it to Hall Of Shame for now:
Hope they resolve this issue with TitanFall, as it looks like a pretty fast paced FPS.
Monitor: Gigabyte M27Q X
WeRGod
Re: Titanfall [frame capped to 60fps]
This may help: http://www.reddit.com/r/titanfall/comme ... ity_issue/hashtonkutcher wrote:Anyone else w gsync playing this Beta? The game's fps is supposedly locked to your displays refresh rate, and it seems when you have gsync enabled the game selects 60hz as the "default" if you could call it that. So basically when I play Titanfall with Gsync enabled I'm stuck at 60fps. Bummer.
- nimbulan
Titanfall uses a 60 fps limit with vsync off but lets the framerate go higher with vsync on. This unfortunately leads to horrendous microstuttering, at least in my case. For some reason the frame limiting behavior seems to be opposite on certain hardware or with certain settings such as insane textures.
