my fps wont feel smooth even its high?
hi blurbusters i got a big problem i got a good system like 2070 , 32gig ram at 3200mhz and 240hz with g-sync so i checked how to use g-sync correctly it says g-sync + v-sync + rtss -3 from my refresh rate so its 237 alright i did it so everything works fine no stutter in rainbow six siege works great at high fps like 200+ or but when it drops too 150 or lower its not fluent anymore is there a way to fix this it really breaks my gaming experince
Re: my fps wont feel smooth even its high?
Drops are what's causing it. you can't drop from >50 frames and expect it to still be smooth. You can try with vsync off and gsync on see if you get better results. You can ultimately try 144hz GSYNC instead of 240hz it should be even smoother , because your monitor will be locked at the frame rate and if the frame rate goes higher than the refresh rate.
Big FPS drops can be caused by the CPU maxing out or the GPU. If it's the CPU, you can get stutters (referred to sometimes as "CPU stutter".) The only way to fix that is by using a lower FPS cap. Use 240Hz g-sync but cap your FPS to something like 150 or 140. Find a good FPS cap for each game that fixes your stutter.
I get 220-260 FPS during normal gameplay, 330 FPS when staring at a wall in Rainbow Six Siege. It's very hard to achieve 240 FPS, you need the very best PC. You didn't list your CPU and RAM timings, stick to 144 Hz.
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
guys i finally found what causes the problem after testing every hardware and doing diagnosis with people i know, its blurrines below a specific FPS(200) it goes blurry tried ULMB and constant refresh rate didnt help. tried my monitors OSD settings didnt help either
i dont have ghosting or any kind of other problems only the blurriness my games are not sharp
Is it blurry even when nothing is moving on the screen or only when there's motion?Zakla7 wrote:guys i finally found what causes the problem after testing every hardware and doing diagnosis with people i know, its blurrines below a specific FPS(200) it goes blurry tried ULMB and constant refresh rate didnt help. tried my monitors OSD settings didnt help either
it goes blurry when moving aroundRealNC wrote:Is it blurry even when nothing is moving on the screen or only when there's motion?Zakla7 wrote:guys i finally found what causes the problem after testing every hardware and doing diagnosis with people i know, its blurrines below a specific FPS(200) it goes blurry tried ULMB and constant refresh rate didnt help. tried my monitors OSD settings didnt help either
i tried setting my HZ to 144 and tried ULMB and constant refresh rate no luck in these too
i checked https://www.testufo.com
240 120 60 fps and the smoothness feels 120fps in games not 240
Edit: i think i just bought a wrong monitor and im stuck with it for now should have bought a 144hz g-sync
What is the name and model of your monitor?
Alienware 25 Gaming Monitor: AW2518H G-SyncChief Blur Buster wrote:What is the name and model of your monitor?
