what settings do i need to get the most out of my native g sync module monitor? (also side question)
kofman13
Post by kofman13 » 30 Jun 2020, 09:29
Just got acer predator XB273X which has native g sync. So far,
In game v sync: off
NVCP V sync: On
are there any other settings i can use in NVCP to get even more out of native g sync ?(since i paid so much lol)
side note: i was playing apex legends with my frame rate fluctuating between 120-170fps, and then i go to G sync enabled, and for SOME reason it feels like with g sync on there is more motion blur? it could be placebo or im going crazy but it felt liek g sync off was a little snappier maybe i was just getting tired last night. anyway, any other settings in NVCP to make g sync even better since i have native module?
Re: what settings do i need to get the most out of my native g sync module monitor? (also side question)
Post by jorimt » 30 Jun 2020, 11:50
kofman13 wrote:
30 Jun 2020, 09:29
G-SYNC on + V-SYNC on (NVCP) + V-SYNC off (in-game) + LLM "On" (as a fallback when/if ever your framerate falls below your FPS limit) + minimum -3 FPS below refresh rate with either in-game or RTSS/Nvidia Max Frame Rate limiters (former has lowest lag, latter have most frametime consistency WHEN your framerate is limited by the cap).
Otherwise, you're already automatically getting the benefit of dynamic/variable overdrive the hardware module provides during fluctuating framerates within the refresh rate (reduces overdrive artifacts such as ghosting/smearing, etc).
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
kofman13
Post by kofman13 » 01 Jul 2020, 16:27
is there any downside to using g sync? besides negligible amount of input lag. (or none if i have module).
also do you think i would notice stepping down to g sync compatible monitor instead of native g sync? i am tempted to get the 25 inch version of my monitor instead of 27 but the 25 is g sync compatible while my 27 inch is g sync native
Post by jorimt » 01 Jul 2020, 16:34
kofman13 wrote:
01 Jul 2020, 16:27
If you don't want tearing, not really, it's the lowest possible lag no-tear solution (across any framerate within the refresh rate) available.
kofman13 wrote:
01 Jul 2020, 16:27
You'll likely lose dynamic overdrive, which reduces overdrive artifacts/ghosting with variable framerates. That, and if you go G-SYNC Compatible, you want to make sure it has "Official" Nvidia support:
https://www.nvidia.com/en-us/geforce/pr ... ors/specs/
Otherwise, it should be comparable in most respects.
