I have my max frame rate capped globally for all games in NVCP at 180 FPS (both for G-SYNC and OBS, as 180 is evenly divisible by 60 for smooth recordings and streams).
If I'm running a game that has its FPS capped to 120 FPS, would that cause any issues, or is it only a problem if both limiters have the exact same FPS cap?
Do external (NVCP, RTSS) and internal (in-game) frame limiters conflict if they are not set to the same FPS values?
Re: Do external (NVCP, RTSS) and internal (in-game) frame limiters conflict if they are not set to the same FPS values?
The higher cap doesn't have a chance to activate, so it's not an issue, especially if one of the two caps is from the in-game FPS limiter.
