Post by jorimt » 13 Aug 2022, 17:30
PWN3D_ wrote:
13 Aug 2022, 13:31
Is limiting your frame 3 frame below your monitor refresh rate really doing everything if for example you are using a "170hz" (an XG27AQ 144hz/170hz with overclocking) monitor that VRR ranges goes from 48Hz~170Hz for DisplayPort, but only use the out of the box 144hz native frequency?
The minimum -3 FPS limit is relative to the currently set max refresh rate.
I.E. if your 170Hz-capable monitor is set to a physical refresh rate of 144Hz, the recommended FPS limit is 141 FPS or under, whereas if that same monitor is set to a physical 170Hz, the recommended FPS limit is 167 FPS or under, and so on.
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
Kyouki
Post by Kyouki » 13 Aug 2022, 19:24
PWN3D_ wrote:
13 Aug 2022, 13:31
In this setup, is 144hz considered display’s maximum refresh rate and therefore a 141fps limit through NVCP is requiered for that smooth g-sync experience, or 170hz is still considered the maximum refresh rate, and a 144fps limit through NVCP(or in-game settings as it's often an option there) is the way to go?
Always -3 fps.
Noisyjam
Post by Noisyjam » 15 Nov 2022, 13:13
Hey I was wondering what settings I should use if I absolutely hate stuttering, I don’t rlly mind screen tearing that much but I absolutely hate stuttering. I have a g sync compatible monitor with a 3070rtx, and I don’t know if I should use g sync on with v sync off or with v sync on, let me know what setting is the best for if I HATE stuttering.
Post by Chief Blur Buster » 15 Nov 2022, 14:07
Kyouki wrote:
13 Aug 2022, 19:24
PWN3D_ wrote:
13 Aug 2022, 13:31
Always -3 fps.
You need a bigger safety margin when you're at higher refresh rates.
So I prefer to always say between 3-5% below.
Post by Chief Blur Buster » 15 Nov 2022, 14:08
Noisyjam wrote:
15 Nov 2022, 13:13
It works best with two separate VSYNC settings (ON in drivers, OFF in game).
Maximum fluidity usually occurs with:
G-SYNC ON in monitor menus
G-SYNC ON in NVIDIA Control Panel
VSYNC ON in NVIDIA Control Panel
VSYNC OFF in-game menus
Cap about 3-5% below maximum Hz using the in-game framerate cap.
You can also try an RTSS cap instead of in-game.
Post by jorimt » 15 Nov 2022, 14:13
Noisyjam wrote:
15 Nov 2022, 13:13
In addition to what the Chief said, there will be system-side stutter either way, so for that, pick your poison:
- G-SYNC on + V-SYNC on = potentially (but not always) longer system-side stutter without tearing per instance
- G-SYNC on + V-SYNC off = potentially (but not always) shorter system-side stutter with tearing per instance
G-SYNC only fixes sync stutter and can not address system-related stutter due to asset loading/streaming, shader compilation, general I/O operation, etc.
emhelmark
Post by emhelmark » 08 Dec 2022, 09:26
In games wherein Nvidia Reflex is present, should i still use -3 fps in-game cap?
Because I observed even though I don't use in-game caps, the fps automatically caps when Nividia Reflex on or on+boost is enabled.
I also assume if Nvidia Reflex is avail, its a must use. Right?
Thanks~
Spec: vp249qgr / r5 3600 stock /b450m / rtx2070 / 2x8gb3200mhz
Settings: nvidia g-sync = on / nvidia v-sync = on / in-game vsync = off / monitor freesync = on (g-sync surprisingly works though, i hope so because g-sync indicator shows when its on)
Post by jorimt » 08 Dec 2022, 10:00
emhelmark wrote:
08 Dec 2022, 09:26
A manual FPS limit is not required when using G-SYNC + V-SYNC + Reflex, since as you observed, Reflex will set an automatic limit of its own slightly below the max refresh rate for the same purpose.
emhelmark wrote:
08 Dec 2022, 09:26
Only if your system can't sustain the framerate at the FPS limit the majority of the time. Reflex only further reduces latency (separate of the latency G-SYNC reduces) whenever the GPU usage is maxed.
dita
Post by dita » 16 Dec 2022, 21:03
Hi, so 1st of all im very new to this forum and i literally cant find where to make a post. Anyways ill ask my question here fuk it. So...im using gsync + vsync in nvcp. My question is...should i also enable triple buffering in nvcp or no and does it matter if i have variable refresh rate in windows settings set to on or off. I switched it to on just to try it and it out feels better but maybe thats just me trippin. So ye...thats all i wanna know basically, thanks in advance 🙃
Post by jorimt » 16 Dec 2022, 23:17
dita wrote:
16 Dec 2022, 21:03
No; G-SYNC natively functions on a double buffer.
dita wrote:
16 Dec 2022, 21:03
Refer to:
https://devblogs.microsoft.com/directx/ ... resh-rate/
