If 120 is the lowest FPS, then cap to 120 and see if you like the result.rasdore wrote: ↑13 Nov 2023, 22:53Good afternoon, thank you for the guide. I play Hunt Showdown on PC and my framerate is not stable even on minimum settings (120-160 fps), as is the frame. Monitor - Asus PG258Q (g-sync, overdrive, 240hz), video card - nvidia suprimx 3080. After reading the manual, I could not find the settings for myself. I ask for your help, I will be glad for any hint. In search of the lowest latency with an adequate frame rate...
I answered your question in my article comments, but as I said there, G-SYNC will not strictly improve performance, only prevent tearing.rasdore wrote: ↑13 Nov 2023, 22:53Good afternoon, thank you for the guide. I play Hunt Showdown on PC and my framerate is not stable even on minimum settings (120-160 fps), as is the frame. Monitor - Asus PG258Q (g-sync, overdrive, 240hz), video card - nvidia suprimx 3080. After reading the manual, I could not find the settings for myself. I ask for your help, I will be glad for any hint. In search of the lowest latency with an adequate frame rate...
What average framerate your system can achieve in that particular game is unrelated to optimal G-SYNC settings and down the capability of your specs, so you'll need to determine your lowest achievable average framerate and then limit it slightly below that target for a more consistent experience.
https://imgur.com/a/0N47wCO
These are my performance with v sync + g sync + low latency + frame limit by nvidia. Is it possible to somehow change the delay? I see gaps in the image when the framerate drops to 100-120. 140-180 is normal.
At 240 Hz, 120 frames in this game look very sluggish and out of sync with sudden movements. If I don’t lower the monitor’s Hertz, is there no way out?RealNC wrote: ↑14 Nov 2023, 08:13If 120 is the lowest FPS, then cap to 120 and see if you like the result.rasdore wrote: ↑13 Nov 2023, 22:53Good afternoon, thank you for the guide. I play Hunt Showdown on PC and my framerate is not stable even on minimum settings (120-160 fps), as is the frame. Monitor - Asus PG258Q (g-sync, overdrive, 240hz), video card - nvidia suprimx 3080. After reading the manual, I could not find the settings for myself. I ask for your help, I will be glad for any hint. In search of the lowest latency with an adequate frame rate...
This is not related to G-SYNC settings. Please create a new topic here:rasdore wrote: ↑14 Nov 2023, 09:34https://imgur.com/a/0N47wCO
viewforum.php?f=2
