I'm french and i search a G-Sync Screen whith NO problem.
A french site recommends this screen SAMSUNG ODYSSEY G9
Could you give me your opinion? Is this a good reference because it is a big investment
Search G-Sync Screen whith NO problem
Reason: Deleted possible SEO spam
Re: Search G-Sync Screen whith NO problem
Salut,
Take a g-sync native monitor if you Can, they have variable overdrive and far more range than gsync compatible
G7 still the best VA panel. But i dont think it is gsync native.
For ips pg279qm is the best ips panel with a g-sync module
