Blur Busters Forums
Acer XB270HA 27" 1080p 144hz
Re: Acer XB270HA 27" 1080p 144hz
Postby 0134RY73 » 20 Nov 2016, 11:53
Can somebody please upload icc profile, jeez thousands of you must have it.
0134RY73
Postby jorimt » 20 Nov 2016, 13:19
0134RY73 wrote:Can somebody please upload icc profile, jeez thousands of you must have it.
If it's someone's profile calibrated specifically for their monitor, it won't help yours anyway. In fact, it will more than likely make it worse. Even if you own the same monitor model as someone else, each panel is physically different. The offsets that are adjusted by the profile to properly calibrated his monitor are going have completely different starting points on yours.
If you don't have your own calibration device, you're better off using the brightness and contrast settings he posted and leaving your color profile at the default.
Blur Busters Contributor - BlurBusters.com | TestUFO.com | Follow @BlurBusters on Twitter!
Previous
Return to G-SYNC
Who is online
Users browsing this forum: No registered users and 1 guest
