Monitor Corsair XENEON 27QHD240 - G-SYNC flickering
Posted: 20 Jun 2023, 08:48
I have problem with my new monitor Corsair XENEON 27QHD240 inside games with activated G-SYNC and Adaptive Sync. In dark scenes, the monitor flickers.
- Monitor is connected with Display Port cable.
- Nvidia driver is 536.23 (latest). In this driver I se my monitor is G-SYNC compatible. Older drivers don't show compatibility info with this monitor.
When I limit the FPS using the game settings or in the Nvidia drivers, the flickering does not go away.
When I switch the monitor to a lower refresh rate, the flickering doesn't go away either. Maybe it's a little weaker at a lower refresh rate.
I attached screenshots with my Nvidia driver settings. Video from game Overwatch 2 with flickering preview and the screenshot with the game settings.
I tested many options in many games, but nothing help.
Only one helps ..... when I deactivate G-SYNC.
This looks like Nvidia driver has wrong support of this monitor or Adaprive Sync inside this monitor is broken.
Next issue (inside Windows):
Some apps (I think .NET apps) as Razer Synapse 3 cause flickering, when move mouse over app active (e.g. menu) items, see attached video.
I wrote a ticket on Corsair, but I want to ask if someone could help. Thank you
Overwatch 2 flickering - FPS no limit
Overwatch 2 flickering - 120 FPS limit
Razer Synapse flickering
