Hi, I recently bought a G-SYNC Compatible monitor (LG27GP850-B) and was trying out the adaptive sync feature. The problem I have is that I constantly run into some flickering issues. When openning certain apps and alt-tabbing the screen goes black for a moment and then turns back on.
The best example I can give is everytime I open the GeForce Experience app the screen always goes black just after I launch it or whenever I get the app back into focus. Talking about fullscreen apps like games, they work perfectly, with no flickering.
Example: https://drive.google.com/file/d/1jYwgek ... drive_link
I have been searching for a solution for a few days but I am getting nowhere. My assumption is that, as the monitor is G-SYNC Compatible it works within a range of fps, and, when launching certain apps I think the frames drop bellow the minimun fps of the G-SYNC which causes the flickering.
My question is, is this normal? I have G-SYNC only enabled for fullscreen apps yet it flickers with windowed apps. It is not the end of the world, it only happens for ~2 secs and only for specific apps but it is a bit anoying. Disabling G-SYNC solves the issue but I would like to have in on.
Specs / Settings:
- Windows 11 fresh install.
- NVIDIA RTX 3070
- NVIDIA driver 536.67 (latest)
- G-SYNC is ON and set to only work for fullscreen only. Still the issue apears on windowed apps.
I have tried the following:
- Disabled MPO (still flickers)
- Increasing the fps range using the "Extended" mode the monitor has (still flickers)
- Changing the refresh rate to 165, 144, 120 and 60 (still flickers)
- Rolling back the NVIDIA drivers as far as I could (still flickers)
- Trying to force an app to not use G-SYNC using the NVIDIA Control Panel (the app still flickers)
- Disabling G-SYNC (solves the issue)
G-SYNC flickering issue
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
