[fixed] Input Not Detected on GSYNC upgrade - help
sharknice
Re: Input Not Detected on GSYNC upgrade - help
Post by sharknice » 17 Jan 2014, 02:18
Upgrading to Windows 8.1 didn't fix anything. I'll probably just reinstall windows tomorrow.
sharknice
Post by sharknice » 17 Jan 2014, 17:34
Well I reinstalled Windows 8.1 and it the monitor worked and windows even identified it as a GSYNC monitor instead of generic monitor, although it was a little weird because it set the refresh rate to 64hz and didn't let me change to anything else. It did let me set the resolution though.
But as soon as I installed the NVIDIA drivers it stopped working. I also tried Windows 7 and it did the same thing as soon as I installed the drivers. I was able to hook it up to my onboard intel GPU and it worked until I installed the intel graphics drivers.
So it looks like it is a problem with the GSYNC kit and monitor. I guess I'll open it up and just try reconnecting everything but it seems very weird to me that it would work fine as long as I'm not using drivers. Could I have got a defective kit?
Post by Chief Blur Buster » 17 Jan 2014, 17:41
Damn!
It's possible -- maybe your monitor has problems running at higher than around 60Hz.
I think this is the type of problem that requires assistance from NVIDIA.
NVIDIA is currently overloaded, so still waiting for a reply to my previous emails to NVIDIA contacts, but if your kit includes NVIDIA contact information, can you contact NVIDIA and see how fast they react through that channel?
sharknice
Post by sharknice » 17 Jan 2014, 18:52
I think I fixed it because it is working now.
It think the LVDS and LCD power cables were swapped in the wrong wholes, but I'm not sure, I just reconnected everything.
Post by Chief Blur Buster » 17 Jan 2014, 19:06
sharknice wrote:I think I fixed it because it is working now.
Aha!
Good to hear that it was just a classic case of "loose wires".
(cue chips, springs, nuts and bolts noisily falling out of an A.M.C.E. Deluxe Monitor, as Wil E. Coyote tries to mod it for G-SYNC)
