Post
by Edmond » 31 Aug 2014, 08:04
More than one GPU has always been problematic. Always.
And now, since you can buy a gsync monitor and you want a totally artifact free gaming, and a smooth, artifact free motion is valued over everything else... more than one gpu makes even less sense and works against your goal.
Sell of any gpus you have before the 900s launch and then get the best single gtx900 you can afford. And just use a single gpu - simple, far less headaches, and you can spend more time enjoying games instead of hitting your head against the wall that is all these problems.
