Blur Busters Forums
Titanfall [frame capped to 60fps]
Postby hashtonkutcher » 15 Feb 2014, 10:53
Anyone else w gsync playing this Beta? The game's fps is supposedly locked to your displays refresh rate, and it seems when you have gsync enabled the game selects 60hz as the "default" if you could call it that. So basically when I play Titanfall with Gsync enabled I'm stuck at 60fps. Bummer.
Also.... Are developers seriously gonna keep doing this to PC gamers?
hashtonkutcher
Re: Titanfall
Postby Chief Blur Buster » 15 Feb 2014, 10:57
hashtonkutcher wrote:Anyone else w gsync playing this Beta? The game's fps is supposedly locked to your displays refresh rate, and it seems when you have gsync enabled the game selects 60hz as the "default" if you could call it that. So basically when I play Titanfall with Gsync enabled I'm stuck at 60fps. Bummer.
This is a beta -- and betas invite feedback -- why don't you report the bug to the developers?
Ideally, it should attempt to sync to the maximum refresh rate that G-SYNC is set at (e.g. 144fps), and let G-SYNC handle smoothing-out any frame rate slowdowns.
(ManuelG at NVIDIA, you might want to give them a call, too.)
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Re: Titanfall
Postby hashtonkutcher » 15 Feb 2014, 11:07
Point taken, reporting it now. I can't be the only one getting tired of all these games with locked framerates and what have you though.
hashtonkutcher
Re: Titanfall
Postby Chief Blur Buster » 15 Feb 2014, 11:17
I've added it to Hall Of Shame for now:
viewtopic.php?f=2&p=2974#p2974
Re: Titanfall
Postby Haste » 15 Feb 2014, 11:41
Chief Blur Buster wrote:I've added it to Hall Of Shame for now:
Excellent initiative! I'll help with populating it.
Hope they resolve this issue with TitanFall, as it looks like a pretty fast paced FPS.
Monitor: Asus ROG Swift PG279Q
Haste
Re: Titanfall [frame capped to 60fps]
Postby WeRGod » 16 Feb 2014, 09:16
This may help: http://www.reddit.com/r/titanfall/comme ... ity_issue/
WeRGod
Postby nimbulan » 17 Feb 2014, 19:57
Titanfall uses a 60 fps limit with vsync off but lets the framerate go higher with vsync on. This unfortunately leads to horrendous microstuttering, at least in my case. For some reason the frame limiting behavior seems to be opposite on certain hardware or with certain settings such as insane textures.
nimbulan
Return to G-SYNC
Who is online
Users browsing this forum: MSN [Bot] and 3 guests
