moep
Post by moep » 03 Aug 2020, 09:52
jorimt wrote:
03 Aug 2020, 09:09
moep wrote:
03 Aug 2020, 08:09
How normal is it to have flickering outside of the G-Sync range on G-Sync compatible monitors?
I just went from an old monitor with a G-Sync module to one that's just compatible. The former had 0 flickering over 5+ years, the latter flickers like crazy outside of the VRR range (VA).
Model?
Samsung Odyssey G7 32".
Post by jorimt » 03 Aug 2020, 11:41
moep wrote:
03 Aug 2020, 09:52
jorimt wrote:
03 Aug 2020, 09:09
moep wrote:
03 Aug 2020, 08:09
Model?
Okay, so what do you mean by "outside of the VRR range" exactly? Do you mean when the framerate is above the refresh rate, or in the LFC range, both? With G-SYNC Compatible on, off or both?
What I can say is, minor flicker is expected with very low frame/refresh rates during loading screens, etc, even on a native G-SYNC display, but it sounds like you may be experiencing it in a different context.
Displays: Acer Predator XB271HU / LG 48CX OS: Windows 10 MB: ASUS ROG Maximus X Hero CPU: i7-8700k GPU: EVGA RTX 3080 FTW3 UG RAM: 32GB G.SKILL TridentZ @3200MHz
