Blur Busters Forums
Questions about new G-Sync monitor
Re: Questions about new G-Sync monitor
Postby parini » 02 Jul 2017, 13:40
I put the 2 side monitors that I have both do so I think the problem is not the monitor.
parini
Postby parini » 02 Jul 2017, 13:49
Could you test on gta too and keep looking up?
parini
Postby jorimt » 02 Jul 2017, 13:51
Wait, you're saying that you have two non-G-SYNC monitors, and you have the brightness issue with those monitors as well?
Does this problem only happen in GTA? If so, it may be an in-game HDR effect at night causing it then, which would mean it has nothing to do with G-SYNC or your monitor at all.
I don't have GTA unfortunately. But again, it sounds like an in-game lighting effect. Try setting GTA to the lowest settings, and see if it happens then.
Blur Busters Contributor - BlurBusters.com | TestUFO.com | Follow @BlurBusters on Twitter!
To support Blur Busters: Official List of Best Gaming Monitors | G-SYNC | FreeSync | Ultrawide
Postby parini » 02 Jul 2017, 14:01
If you want I'll give you an account of the game. I've got two here.
parini
Postby jorimt » 02 Jul 2017, 14:03
If the brightness issue is only happening to you in GTA V, it is likely GTA V's "Post FX" setting.
One of those effects (HDR lighting) simulates the human eye adjusting to light sources, which makes brightness fluctuate like that.
It is probably the game.
Postby parini » 02 Jul 2017, 14:07
Now I'm going to do a battery of tests in another game here and I'll give you the answer again.
parini
Postby jorimt » 02 Jul 2017, 14:23
Yes, it looks like the game is causing it.
Postby Chief Blur Buster » 13 Jul 2017, 15:50
Yes, some games have a HDR mode that dynamically adjusts global brightness of game based on average brightness of scenery, as a HDR effect. Half Life 2 Episodes in "HDR" mode did this, too.
Previous
Return to G-SYNC
Who is online
Users browsing this forum: Majestic-12 [Bot] and 3 guests
