Page 1 of 10
Posted: 29 Jun 2017, 13:05
by parini
Tomorrow my monitor arrives, as I live in Brazil, everything is slow, I'll give you the feed, another question I bought a XB241YU 165hz and I wonder if his gsync works at 162hz because it's overclocked to 165 more default is 144hz
Posted: 29 Jun 2017, 13:16
by jorimt
Yes parini, if you're monitor is running at 165Hz, you want a 162 FPS limit with G-SYNC, if it's at 144Hz, you want a 141 FPS limit.
The framerate limiter always needs to be set 3 frames below the current maximum refresh rate to avoid V-SYNC input lag with G-SYNC.
Posted: 29 Jun 2017, 13:17
by parini
Thank you, sorry for the inconvenience.
Posted: 29 Jun 2017, 13:21
by jorimt
No worries, parini
Posted: 29 Jun 2017, 16:44
by parini
When I activate vsync on the nvidia control panel does gta v open at 72fps normal?
Posted: 29 Jun 2017, 17:29
by jorimt
parini wrote:When I activate vsync on the nvidia control panel does gta v open at 72fps normal?
Do you have your G-SYNC monitor yet? It looks like you don't have G-SYNC enabled. You want G-SYNC + V-SYNC, not V-SYNC only.
It sounds like you're running GTA V on a standard 144Hz monitor with only double buffer V-SYNC enabled. This would lock your framerate to half the refresh rate (72 FPS) if you can't sustain 144 FPS or more at all times with V-SYNC only.
G-SYNC + V-SYNC would not do this.
Posted: 30 Jun 2017, 13:34
by parini
If my native resolution is 2k and I play 1080p in the game will gsync work normal?
Posted: 30 Jun 2017, 13:54
by parini
Do I also leave my overdrive on my monitor?
Posted: 30 Jun 2017, 13:57
by RealNC
Yes and yes.
Posted: 30 Jun 2017, 14:20
by parini
When I leave in extreme the overdrive when it falls the fps inside the gsync in the bf3 gives a frozen fast as if it were stturtering
