Seeking G-Sync Settings Guidance
Posted: 05 Oct 2018, 11:36
I recently discovered the G-Sync articles from Blur Busters despite having had a G-Sync display from way back in the day BenQ XL2420G (day 1) and I feel stupid for not having configured usage of it correctly for all this time (didn't know about requiring V-Sync for example because at the time, it was thought you were supposed to disable V-Sync everywhere or use Fast Sync later on; and I didn't know that more research had been done).
Anyway, I've read through many threads and articles since then in the past couple days but there are still a few things I'm not sure about and I'm hoping someone could clarify for me. Based on what I understand so far, I have G-Sync on, V-Sync on via NVCP, and using RTSS to globally limit frames to 141 (144Hz display).
The stuff that are a bit ambiguous to me though are these:
1. If in-game frame limiters are better than using RTSS, my current understanding is that I should use the in-game one. However, if the options in-game are fixed, for example 30-60-90-120-144, should I be choosing 120 or 144 (or other)? Or... should I just continue to use RTSS set to 141 regardless since I would lose up to 21fps otherwise? I don't have any idea what impacts there would be in this scenario on performance or input latency.
2. I also understand that if I don't ever reach the max frames (in this case for 144Hz) but I get stable fps, G-Sync+V-Sync is still optimal? Or is it dependent on how far below 144 fps? And if so, what is the best solution?
3. If I use RTSS to frame limit globally for 141 (for 144Hz) and I also frame limit in-game (to what would be optimal in 1.), barring weird conflicts or incompatibilities, does that have any impact significant impact on performance or input latency? I know it's redundant at that point but it's just so I don't have to think about loading it for each game that doesn't have a frame limiter (especially when I have the backgrounds resources to leave it alone).
I apologize if these type of questions have been answered already, I tried to find the answers but it's difficult since searching brings up the same terms over and over again but not necessarily the answer I'm seeking.
