Blur Busters Forums
Scanline RTSS
Scanline RTSS
Postby Abiak » 31 Oct 2018, 14:15
The new version of RTSS has scanline sync, I wonder if I should use it with gsync?
Abiak
Re: Scanline RTSS
Postby Chief Blur Buster » 31 Oct 2018, 14:18
Scanline sync is not designed for use with VRR at this time.
The use of scanline sync is best for a "low-lag VSYNC ON" where you got perfect "framerate equals Hz" synchronization without tearing. As a vendor-agnostic equivalent of NVIDIA Fast Sync / AMD Enhanced Sync that does not have microstutters (at full framerates).
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Re: Scanline RTSS
Postby RealNC » 31 Oct 2018, 16:46
Chief Blur Buster wrote:Scanline sync is not designed for use with VRR at this time.
Nor is it needed :-)
Scanline sync is a solution for people who don't have a g-sync display. If you do have g-sync, then it already does what scanline sync provides, but much better.
(So one could say scanline sync is the poor man's g-sync :P)
Re: Scanline RTSS
Postby Chief Blur Buster » 13 Dec 2018, 23:49
RealNC, let's be thorough here ;)
Scanline sync can still be useful for users who already has VRR
--> when you need to run games not compatible with FreeSync/G-SYNC
--> when you need to use motion blur reduction (e.g. ULMB).
Motion fluidity of ULMB (and other motion blur reduction backlights) benefits from VSYNC ON -- so some of us want to gain a reduced-lag VSYNC ON mode for better-looking ULMB without as much lag penalty.
There are a few other use cases for Right Tool For Right Job. But it's indeed true that if you can play with VRR with an in-game framerate cap, it is usually superior to scanline sync especially if your framerates are always running well below VRR max rate.
Re: Scanline RTSS
Postby 1000WATT » 17 Dec 2018, 16:35
winver 1607, wddm 2.1, nvidia 388.59, vsync off
https://youtu.be/-NQVSM1H1Ns
1000WATT
Re: Scanline RTSS
Postby Chief Blur Buster » 17 Dec 2018, 16:53
That tearline jumps too much for scanline sync to be useful. Try SyncFlush=1 in the config file.
Re: Scanline RTSS
Postby 1000WATT » 17 Dec 2018, 17:33
Sorry for not writing in English. I have no problems and I am not looking for help. I wanted to tell you that in some cases, scanline sync helpful for vrr display. Your offer does not work for me ( https://youtu.be/XK2q0RCENb8 ).
My version may help this guy viewtopic.php?t=3436#p26762 .
(It is particularly noticeable in Battlefield 1 and to a lesser extent in Witcher 3 (both using in-game capping). It seems to be mostly the case however when there is a lot going on or many assets being loaded in quickly. For example, when walking around in Witcher 3, I can't see any tearing at all, but when sprinting I do see some minor tearing now and again in the bottom of the screen (although you can only notice it when you really focus). When sprinting and looking at the sky, I can't see any tearing either, consistent with there being fewer assets.)
1000WATT
Return to G-SYNC
Who is online
Users browsing this forum: No registered users and 6 guests
