Out of sync or motion blur
GoG
Post by GoG » 01 Dec 2018, 21:04
Good night!
I recently bought the AW2518H 240Hz G-SYNC monitor, but I found that when I am playing fortnite or counter strike, when I move while I move the mouse sideways, I can see that the game is out of focus (just a little bit) .. What could be ?
Thanks!
Kheri
Re: Out of sync or motion blur
Post by Kheri » 02 Dec 2018, 02:48
I think that's a good mointor.. Maybe overdrive response times are set too fast? Maybe the in-game "motion blur" setting is on? Or maybe it's just normal sample-and-hold motion blur Thought I'd answer first, but you'll get more responses from others.
GoG
Post by GoG » 02 Dec 2018, 16:19
Settings are normal and motion blur is off, the image is not total blur, only the graphics inside the game are, like at Fortnite, the characters stays blur when using movement ASWD and aiming while moving the aim to left or right at same time! Only at same time! When im stopped and aiming only(without moving), It stays fine...
Maybe some settings at Nvidia that i Should turn off?
Thanks!
