Because I wouldn't be utilizing what I paid for...RealNC wrote:I don't see how what you paid for affects what you get in any waybesweeet wrote:I opted to just deal with the limit. I paid for 155Hz and shouldn't have to decrease my frame rate.
Dell S2719DGF - I don't think G-SYNC CM is working...
Re: Dell S2719DGF - I don't think G-SYNC CM is working...
Hi, I have a question that might be stupid.
I have a gtx 970 and I'm thinking about buying the Dell S2719DGF.
Will I be able to use ULMB(or what ever the alternative is for this monitor) and Gsync with this Monitor?
I normaly only play Dota2 and my FPS are fixed around 80 FPS.
No. This is a freesync monitor. To use use freesync on an nvidia GPU, you need a 10xx nvidia card or newer. The 970 does not support it. Also, this monitor doesn't have any motion blur reduction mode.crudolol wrote:I have a gtx 970 and I'm thinking about buying the Dell S2719DGF.
ooh thanks a lot. was about to order it.RealNC wrote:No. This is a freesync monitor. To use use freesync on an nvidia GPU, you need a 10xx nvidia card or newer. The 970 does not support it. Also, this monitor doesn't have any motion blur reduction mode.crudolol wrote:I have a gtx 970 and I'm thinking about buying the Dell S2719DGF.
so maybe the s2716DG sohuld be my way to go. thanks
Yes, the S2716DG (or S2716DGR, it's the same) will work in either g-sync or ULMB mode on a 970 just fine.
RealNC wrote:Yes, the S2716DG (or S2716DGR, it's the same) will work in either g-sync or ULMB mode on a 970 just fine.
I know it might be not the right spot - but if I can get the S2716DG for 400€ - do you think that would be worth it or is there another one you would recommend?
I know its a bit off-topic
