Did i setup gsync correctly?
Posted: 25 May 2019, 07:29
by yungracks
Hey, i got an acer predator xb241h, which i OC'd to 180hz.
Im wondering if i setup gsync right, my LED doesn't function:
https://prnt.sc/nsz0l8
https://prnt.sc/nsz0ws
https://prnt.sc/nsz11f
https://prnt.sc/nsz17o
I got gsync indicator on aswell, says gsync on.
I also capped Fortnite -3 (177fps) ingame.
I still lagg below 120 fps as stated in my other post, so i was wondering maybe i didn't setup gsync up well.
Re: Did i setup gsync correctly?
Posted: 25 May 2019, 08:44
by jorimt
Check to see if you have a "Refresh rate num" option in your monitor's OSD and turn it on. A yellow number overlay should appear in the top right corner of your monitor.
Whenever G-SYNC isn't active, it will show a static "180" (Hz/FPS) readout at all times. Whenever G-SYNC is active, it will fluctuate continuously with the framerate, which will tell you whether G-SYNC is working.
Posted: 25 May 2019, 09:08
by yungracks
jorimt wrote:Check to see if you have a "Refresh rate num" option in your monitor's OSD and turn it on. A yellow number overlay should appear in the top right corner of your monitor.
The yellow thing goes under 177 FPS yes, ingame i got it capped on 177 but how am i supposed to see if it works than?
It just shows my fps?
Posted: 25 May 2019, 09:22
by jorimt
The yellow meter shows G-SYNC adjusting the refresh rate to the framerate in real-time. If it is fluctuating, then G-SYNC is active.
