If you're using borderless/windowed G-SYNC mode, and you click over to your secondary monitor, then G-SYNC becomes inactive on the primary monitor until you focus on the game window again.yungracks wrote:Welllll ummmm judge for yourself im CONFUSED, in the pic you see its on 180, which is when im on my second monitor with my cursor
Rapid readout fluctuations around and above the set FPS cap on the monitor's built-in yellow refresh rate meter is normal. It happens on mine too, and mine is a completely different monitor model (XB271HU w/IPS panel).yungracks wrote:Please check the screen & the video.
The 177 is my ingame cap & the yellow is the monitor refreshrate tester.
https://prntscr.com/nxzkhz
https://www.youtube.com/watch?v=y0DOf351W9M
When I did my original G-SYNC 101 input lag tests on a 240Hz monitor, the built-in refresh rate meter did the very same thing, and with the in-game Overwatch cap set to 237/238 FPS (for 240Hz) my test numbers showed it didn't actually affect the input lag levels at all.
TLDR: it's just false positive readings because the yellow meter isn't 100% accurate. It's normal.
