Have I always made a mistake?
Zazie
Post by Zazie » 23 Oct 2019, 15:23
I I have activated Gsync with enabling this option:
https://ibb.co/qgGb4NH
pox02
Re: Have I always made a mistake?
Post by pox02 » 23 Oct 2019, 15:36
no gpu scaling dont add any input lag but choose no scaling u can use display scaling on older driver u have to check it out
monitors xg258q aw2518hf 27GK750F-B pg248q xg240r lg w2363d-pf xb270hu
Zazie
Post by Zazie » 23 Oct 2019, 15:56
But if I understand to activate gsync actually I also have to activate vsync from the panel. Quite right?
BlurBoss
Post by BlurBoss » 26 Oct 2019, 06:31
No, you don't need to activate V-Sync anywhere to enable G-Sync. You can try G-Sync Pendulum app that allows you to better see the difference. https://www.nvidia.com/coolstuff/demos#!/g-sync
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
Zazie
Post by Zazie » 26 Oct 2019, 06:40
Ok, but I need to activate this: https://ibb.co/qgGb4NH
ToastyX
Post by ToastyX » 26 Oct 2019, 12:53
I don't think G-SYNC monitors can display non-native resolutions with G-SYNC enabled, so you need to use GPU scaling if you want to use lower resolutions. For the native resolution, it doesn't matter.
pox02
Post by pox02 » 28 Oct 2019, 11:47
use lower driver :) problem fixed
Zazie
Post by Zazie » 28 Oct 2019, 12:39
Eh? What version?
Post by RealNC » 08 Nov 2019, 06:25
ToastyX wrote:I don't think G-SYNC monitors can display non-native resolutions with G-SYNC enabled
Thought that as well for a long time, but it seems it is possible. Although in a limited (and quite useless) way:
viewtopic.php?t=3313
So for most intents and purposes it seems that yes, it's not possible, unless you're OK with a low refresh rate (which defeats the purpose of wanting a lower resolution to gain FPS.)
