Hello,
Does anyone here own this monitor?
I had the TN panel version of this monitor but sent it back eventually as I couldn't get on with TN panel.
I am very curious about this monitor, it's cheaper than the TN version, difference being the TN had a G-Sync module and this one is Adaptive Sync/G-Sync Compatible.
Is there any real downside to G-Sync Compatible compared to the module? I see a lot of monitors are opting for the G-Sync compatible cert now to save money.
Acer Predator XB253QGP 144Hz IPS
Acer Predator XN253QX 240Hz G-Sync
Re: Acer Predator XB253QGP 144Hz IPS
It seems they are releasing a 240Hz version @ £350 too.
Would IPS be THAT much slower than TN?
