Hello,
I have a little question about low latency mode, i tried it in CS:GO today with the "ultra" setting cause my fps are always above my refresh rate (144) and i experienced some “rollforward" in-game, it feels like lagging but it's not connection lag, because when i switch back to low latency mode - On, i don't have this issue. The thing is, "ultra" settings feels a lot smoother than the "on".
Anyone has experienced the same issue ?
Setup :
Display : Asus VG258Q (GSYNC COMPATIBLE - GSYNC ON)
Proc : i7 4770k
MB : Asus Z87-A
RAM : DDr3 16go (4x4) 1600mhz
GPU : GTX 1070 8go
My games are installed on an SSD
FTTH connection with min15~30max ping
Thank you
Low latency mode
Re: Low latency mode
First off, what are your G-SYNC settings? Secondly, have you checked your average GPU usage in a typical match?
Hello and thank you for your answer !
Gsync enabled on screen
In NVCP :
- Gsync compatibility ON
- LLm : Ultra
- V-sync : ON
I didn't checked my gpu usage yet, but i checked the CPU usage : approx 40% max.
I'll edit this reply once i have de GPU usage % !
Thanks
In NVCP :
- LLm : Ultra
- V-sync : ON
Thanks
Sure, just post that number in a new reply so I'll see the notification.
