Page 1 of 2
Are there any advantages of gsync on + vsync off over gsync on + vsync on??
Posted: 11 Apr 2020, 11:56
by fowteen
with -3 fps cap in both scenarios
Re: Are there any advantages of gsync on + vsync off over gsync on + vsync on??
Posted: 11 Apr 2020, 12:39
by jorimt
fowteen wrote: ↑11 Apr 2020, 11:56
Tearing.
Posted: 11 Apr 2020, 12:42
by fowteen
okay thanks that's what I thought. I was just making sure I understood this correctly.
Posted: 11 Apr 2020, 13:03
by jorimt
fowteen wrote: ↑11 Apr 2020, 12:42
Yeah, at the same framerate within the refresh rate, G-SYNC + V-SYNC off and standalone V-SYNC off have up to 1/2 frame (so anywhere from 0 to 1/2 frame) advantage in input lag at any given point when compared to G-SYNC + V-SYNC on. This is exhibited as tearing; whenever you see the tear, you're seeing you're literal (and
only) input lag reduction over G-SYNC + V-SYNC on.
Posted: 11 Apr 2020, 13:11
by fowteen
wait what do you mean by gsync+vsync off and standalone vsync off
Posted: 11 Apr 2020, 13:16
by jorimt
fowteen wrote: ↑11 Apr 2020, 13:11
- G-SYNC + V-SYNC on = G-SYNC ON + V-SYNC ON
G-SYNC + V-SYNC off = G-SYNC ON + V-SYNC OFF
standalone V-SYNC off = G-SYNC OFF + V-SYNC OFF
Posted: 11 Apr 2020, 14:25
by fowteen
so gsync+vsync off's advantages over both on is only less input lag?
Posted: 11 Apr 2020, 14:34
by jorimt
fowteen wrote: ↑11 Apr 2020, 14:25
Tearing. When you're asking for less input lag in this case, you're asking for tearing. There is no other difference but that between G-SYNC on + V-SYNC off and G-SYNC on + V-SYNC on
inside the refresh rate.
Posted: 11 Apr 2020, 15:05
by fowteen
but you said gsync+vsync off has an advantage in input lag over gsync+vsync on
Posted: 11 Apr 2020, 15:10
by jorimt
fowteen wrote: ↑11 Apr 2020, 15:05
The input lag advantage
is TEARING
G-SYNC + V-SYNC is the fastest a single frame can be displayed
tear-free; for any faster delivery, it
has to tear (aka G-SYNC on + V-SYNC off or G-SYNC off + V-SYNC off).
That is your
only input lag "advantage" over G-SYNC + V-SYNC:
tearing.
