I play Fortnite a lot and I have been seeing this weird behaviour with g sync where I go into game and it's really jittery for about 20-30 seconds and I have to alt + tab and tab back into the game for g sync to properly work again all I have is stock NVCP settings, I haven't change anything yet. This could be a faulty g sync chip I don't really know yet.
SPECS:
I9 9900K
ROG STRIX 2070 SUPER
TUF Z390-PLUS GAMING (WI-FI)
Alienware AW2518H (Primary Monitor)
Alienware AW2518HF (Secondary Monitor)
G Sync jittery until i alt + tab back in game
Re: G Sync jittery until i alt + tab back in game
I think that's just how fortnite works, it happens to me aswell with freesync
Ok, I guess I was being nuts here but I created a similar topic a small while back:
viewtopic.php?f=5&t=6565&p=48518#p48518
I have the exact same issue in CSGO, this looks like a driver issue. I wonder if Nvidia is aware of this.
Seems like its both jittery but also can cause huge fps drop. Ive seen 800+fps uncapped vs 400ish uncapped in the exact same position, alt tab fixed that too (temporarily). Something is really wrong with the newer drivers. Try 43x branch and tell me if it fixed it for you.
Not sure if its pure coincidence, I also have an Alienware monitor though.
LTSC 21H2 Post-install Script
https://github.com/Marctraider/LiveScript-LTSC-21H2
System: MSI Z390 MEG Ace - 2080 Super (300W mod) - 9900K 5GHz Fixed Core (De-lid) - 32GB DDR3-3733-CL18 - Xonar Essence STX II
