Jerky gameplay in DX12 titles with G-Sync laptop
vorob
Post by vorob » 25 Apr 2020, 18:52
Basically my issue is simple. Almost every game that works in DX12 is jerky with G-Sync enabled. I've got Acer Triton 500 - i7 8750H / RTX 2080 MAX-Q with 144Hz 1080p panel. Any game in DX11 with G-Sync enabled play smooth. But not the DX12 titles. Just take a look at this side by side comparison in MW: https://youtu.be/-Pkz0Gb5ni0
Don't bother for windowed mode on the right, I have G-Sync enabled only for fullscreen applications so turning in windowed mode equals G-Sync off.
I honestly don't understand it. I thought G-Sync is only about varying display refresh rate. How instead of a super smooth image I'm starting getting totally opposite?
vorob
Re: Jerky gameplay in DX12 titles with G-Sync laptop
Post by vorob » 16 Apr 2021, 02:01
It's still a thing on my laptop :)
Shadow of the Tomb Raider, take a look:
https://youtu.be/e-i73-hynVU
When I'm in DX12 and G-Sync is ON I've got horrible stuttering. If I switch to DX11 everything is smooth. Also, no stuttering when G-Sync is OFF in DX12.
vorob
Post by vorob » 25 Oct 2021, 01:33
Okay, case solved. I switched from a balanced power plan to performance and it solved the stuttering issue. Took 2 years to understand this.
https://youtu.be/cxcAvgawnjg
vorob
Post by vorob » 26 Jun 2023, 04:57
The issue is back, in some way. Now i've got another laptop with G-Sync screen. It's Redmi G Pro 2020 with i9-12900h and geforce 3070ti and 240hz panel. The best possible example was captures in BF2042, take a look:
https://youtu.be/0UV4CN6Ml1k
G-Sync is set to work in fullscreen only so when BF2042 is in fullscreen i've got strange hiccups, and if i switch to windowed mode (where g-sync is not working) everything is smooth.
I've noticed same stuff in Diablo 4, but hiccups happens less often, but still they are absent in windowed mode.
bumbeen
Post by bumbeen » 27 Jun 2023, 04:53
maybe it's doing copy through igpu? what does gpu util show for the integrated when running full screen?
Baifsta
Post by Baifsta » 29 Jun 2023, 01:48
I think it's copying over igpu.backrooms
