G-SYNC not working
Posted: 13 Jul 2020, 13:59
Hi i have CRG5 240hz 27inch Gsync compatible monitor , and my pc has GTX 1660 6gb GPU i enabled freesync in monitor and in geforce control panel BUT the problem is it works fine when the (enable settings for the selected display model is not cheked) if i enable thes settings option than all games have terrible ghosting and white lines when in motion ,but the fps looks much more smoother than when this option is not on . i tried messing with ALL the options in the geforce control pannel but nothing works , how can i play games when this option is enabled without the white lines when in motion ?
https://ibb.co/61q7KHN
